more ''new'' 302 motor info
Old Dec 10, 2001 | 05:53 PM
327fire's Avatar
I am very Familiar with the old 327 block and 283 crank but i have not heard of the 4.3 v8 crank and rods. anyinfo would be great
Old Dec 10, 2001 | 06:42 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
A 302 is a 5 liter motor. I would belive that a 265,( the first small block V8) would be a 4.3 liter. That motor itself was a very bad design, comparing it to the modern small block. The 302 comes from a combination of a block with a 4" bore, and a 283 crank. Both the 283 and the 327 shared the small journals, as you probably already know. That's why creating an original 302 is so tough. But you can buy spacers that will make that crank work in a 350, or a large journal 327. But finding that 283 crank isn't easy.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Dec 10, 2001 | 07:05 PM
Tas's Avatar
Tas
its is designated the L99. 4.3L v8 in the B body Caprice cars. I guess the old people wanted a smooth v8 and not a 4.3L v6. They made it the same years(maybe a few less) as they made the LT1. That info should make it easier to find. The rods are 5.94" and match up with LT4 pistons (That's what the GM show car used)
-Tas
'89 Formula WS-6 made in Van Nuys, CA, U.S.A.
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
[This message has been edited by Tas (edited December 10, 2001).]
Old Dec 10, 2001 | 07:10 PM
stingerssx's Avatar
That's right. That's the LT1 that was built in a 265 cid in memory of the first small block. I forgot about that one. I would think that if you wanted to use one of those cranks for a 302 build up, then you'd need to go with a 400 block. I'm just guessing here.
Old Dec 10, 2001 | 10:49 PM
Tas's Avatar
Tas
<font face="Verdana, Arial" size="2">Originally posted by stingerssx:
That's right. That's the LT1 that was built in a 265 cid in memory of the first small block. I forgot about that one. I would think that if you wanted to use one of those cranks for a 302 build up, then you'd need to go with a 400 block. I'm just guessing here.</font>
That crank in a 400 block gets you a 325 or 327 (I forget exactly). Put it in a 350 and you get a 302. 400 blocks are 2 piece rear seal and the L99 is 1 peicee so I don't know if you can do it. I gorget which the adapter lets you do.
-Tas
Super GRK_Taz World
F-Body Dual Exaust
Old Dec 11, 2001 | 04:11 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
get a used motor from the caprice 4.3L.you'll need an 86-later 350 engine block.since the deck heght was unchanged from the 3rd gen block to the 4th gen block i would think replacement parts like pistons(4.030 bore considering wear on the 350 core)rods will work.you may wanna go to 6.00 rods being that the piston will be easier to find in that configuration if money isn't a problem.as for the seal standard gm there.along with most everything else.a correction on a previous post chevy did make the 327 in a large journal(2.45) along wth the small journal(2.30).just a side note the 400 had 2.65 mains and putting that crank into the 400 would yeild roughly 326 cu.in.
Old Dec 13, 2001 | 03:58 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Has any one tried destroking a 86+ 350 with the 4.3L crank? A modern day 302 that has all the roller cam machining already there. I wonder how it would run with a LT4 hot cam and some AFR heads. Also who makes the pistons for that setup.
Reborn756
Sep 4, 2015 03:42 AM
Randomtask2
Aug 26, 2015 03:34 PM
michealleger
Aug 26, 2015 03:29 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
