need HELP with swap
Old Mar 11, 2010 | 08:33 PM
hazlt1's Avatar
Car: 1989 chevy camaro RS
Engine: 1995 Lt1
need HELP with swap
I have a 1982 berlinetta v6 with a 4 speed standard transmission and i am putting in a 1987 350 tpi. The question is will the same 4 speed transmission from the v6 fit on the 350??
Old Mar 11, 2010 | 09:08 PM
Pocket's Avatar
Car: 91 Trans Am
Re: need HELP with swap
Cut down the input shaft or use one from a V8 car and it will in conjunction with the V8 bellhousing. Unless its a T-10 it wont live very long (V6 and most V8 cars got old saggy)
Dont forget you will need some sort of interface for the speed input. The berlinetta is most likely electric so you may luck out and not have to change anything
Old Mar 11, 2010 | 11:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'82 Berlinetta did not have digital dash.
Old Mar 11, 2010 | 11:33 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
If it's a saginaw trans,it's not as awful as it could be.They are far from a Muncie,but they will stand up to a fair bit of whoopin'.Just know that down the road,sooner or later you'll be hunting a T-10.I'd trust a saginaw 4 speed over a T-5.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
