Dyno Results
Old Mar 13, 2010 | 03:56 PM
bullzz's Avatar
Car: 1984 Trans Am, 2003 Z06 Vette
Engine: zz383
Axle/Gears: 9" moser 3.70
Dyno Results
Hi All,
I recently Dyno'd my car and was wondering if the numbers are more or less where they should be. My set up is as follows:
- zz383 crate engine (timing set @10 degrees\650 rpm with vacuum sec disconnected).
- 700r4
- 2400-2600 Stall Convertor
- 3" y-pipe to 4" catback Magnaflow from Mufflex (no cat)
- Hooker 2210 LTH
- Holley Street Avenger 770CFM (stock settings)
- Dual Plane Manifold
- Moser 9" with 3.70 gears
- MSD ignition 6AL and MSD distributor
- UMI SFC
- No AC
- Electric Fan
Thanks.
Old Mar 13, 2010 | 07:56 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Dyno Results
That's just about right. Figure that a stock 700R-4 at stock line pressure, combined with a 7.625" 10-bolt, will eat about 22% of your output, so take your results, divide by 0.78. The difference is probably mostly in your choice of torque converter.
Old Mar 14, 2010 | 10:21 PM
bullzz's Avatar
Engine: zz383
Re: Dyno Results
What torque converter would you recommend for a "weekend warrior" street car?
Old Mar 15, 2010 | 09:28 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Dyno Results
I have no issue with the converter you have. I just wanted you to be aware that if the calculated numbers for engine output don't match GM's advertised numbers, the reason must lie in the torque converter. Some converters are slightly more efficient, some slightly less efficient. Better to be losing maybe 2% more power with the converter you have than to spend many hundreds of dollars looking for another 10 rwhp by trying every converter on the market.
Falcon50
Aug 22, 2020 03:26 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
