Carb to TPI - Now Temp & Oil gauges are whacky
Old Mar 24, 2010 | 06:52 PM
Mr.84TransAmer's Avatar
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
I'm hoping someone's run into this before. I dropped an L98 TPI 350 into my 84 (originally carb'd 305). None of the dash harness has been touched - it's all original from the 84. Now my oil gauge is pegged to the right and my temp gauge is 20* hotter than it should be (a diagnostic tool confirmed this). Sending unit on the temp gauge was tested and shown to be working at the correct voltage. Am I SOL in getting these to work with the new motor?
Old Mar 25, 2010 | 09:57 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Carb to TPI - Now Temp & Oil gauges are whacky
I would use a mechanical oil pressure guage on the motor to verify that the oil pressure guage in the car is wrong.
Old Mar 25, 2010 | 01:27 PM
Pocket's Avatar
Car: 91 Trans Am
Bad senders like to max the gauge, usually as soon as you turn the IGN on
CTS' changed resistance values over the years. You may just have to live with it being a little low if you cant find a CTS from your 84. With coolant, you really only need to know 4 conditions: cold, barely showing a temp, operating temp, and too hot
It should be obvious when each of these conditions are met
Old Mar 25, 2010 | 04:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not to nit pick (but being nit picky), the CTS is different from the temp gauge sending unit. The CTS should be what was with the TPI. The temp gauge sending unit from the '84 should fit in the L98 head and give the proper reading.
Ditto the oil pressure sending unit. The '84 unit should work with the L98 engine. Also, be aware that a shorted wire will peg the gauge - make sure you didn't pinch that wire somehow during the engine install.
Old Mar 25, 2010 | 06:52 PM
Pocket's Avatar
Car: 91 Trans Am
Sorry, Ive gotten too used to the newer LS1 combo sensors. You are correct, they are senders
89GTAOz
May 16, 2020 09:31 AM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
