corvette 113 heads
Old Mar 26, 2010 | 10:03 AM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
corvette 113 heads
does anyone know if the vette 113 heads will except, without mods the old style sbc intake? also what intake gasket would i need? the vette uses a differant one from the regular sbc. any help would be great thanks
Old Mar 26, 2010 | 10:29 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: corvette 113 heads
i pretty sure the center bolt holes are angled differently so the old intake wont work without mod. the felpro 1204 gasket is a good one. here is a thread about those heads
https://www.thirdgen.org/forums/tpi/...tte-heads.html
Old Mar 26, 2010 | 10:31 AM
gta007's Avatar
thanks alot of your reply. I have heard conflecting info on this subject. I will find out real soon either way. thanks
Old Mar 26, 2010 | 10:41 AM
if the heads were made after 86 they should have a different intake bolt pattern.
Old Mar 26, 2010 | 01:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
NOT TRUE!
The 113's have the '86-earlier bolt angles/pattern. They were used on the ZZ3 & ZZ4 crate engine, and that intake has all 90 degree bolt holes (have one of those manifolds on Berlinetta #1).
Old Mar 26, 2010 | 01:15 PM
gta007's Avatar
WOW . thanks for the reply 5.7! that would mean the 87 later tpi vette intakes are differant from the 87 later f-car. I wonder why GM did this. also the tpi vettes all ran a large cap hei. they must have planned on using those heads for gm performance catalog.
Frozer!!!
Jan 19, 2024 04:55 PM
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
TreDeClaw
Aug 14, 2015 06:58 PM
