Another 305 build!
Old Mar 28, 2010 | 12:08 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Another 305 build!
Hi i have a 87 iroc Camaro. My motor locked up on me and so i gotta build another one...Alot of people told me to go 350 but i really like the little 305 and think it could make some power...I wanna make at least 250 hp...But i got some questions i wanna ask u experts out there..1 st i am going to use the same heads from my lb9 what cam would be good for the motor? Second should i use the same pistons that came in the motor i bought..i heard it run and it sounded real good..but wanted to see if maybe i should swap then...anything thing else that somebody could help me out to get that much hp would be great..im going to run the stock tpi set up it came with..thanks alot any help would be greatly appreciated. thanks again.
Old Mar 28, 2010 | 12:21 PM
PT3BOOMER's Avatar
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
Re: Another 305 build!
Hate to say it bro....go with the 350....you'll spend more money making the 305 fast than you would a 350
Old Mar 28, 2010 | 12:28 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
stick to a 350 more hp for the buck
Old Mar 28, 2010 | 12:54 PM
Engine: 350 tpi
well...i got a good price on a 305..and i wanna try to keep the car a 305 like it came with..when im done this will be my daily driver thats why i dont wanna do anything too crazy.
Old Mar 29, 2010 | 09:04 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
250 hp from a 305 isn't even a challenge. Heck, you don't even need to port the heads. Start with headers and exhaust, then do the intake, then go for a mild cam. Something like a 218/224-112 is more than enough. To make use of it, get a 3.73:1 rear gear.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
Reborn756
Sep 4, 2015 03:42 AM
makaveli09
Aug 12, 2015 09:07 PM
