89 caprice cop car motor in an rs? or a really fancy lawn ornament?
Old Apr 7, 2010 | 09:41 PM
chevyhead420's Avatar
Car: 92 camaro 25th anniversary edition
Engine: 305 Tbi
Transmission: auto
so today i stumbled across an 89 rs that has literally become part of someone's yard to be quite honest im not even sure how we found it but anyway i know what our thinking. this car is junk well its not, some how some way there is no rust on it anwhere no dents nothing. so let me get to the point the guy tells me that 10 years ago he put an 89 5.7L caprice cop car motor in it and drove it for sometime until the TBI went along with a water pump and the project became a lost cause. so my question is this is there anyway WITHOUT takin the motor out to tell if this is really a cop car motor??? the 65 yr old man who this amazing looking car belongs to tells me he only wants $500 for this car.... i still think im dreaming
Old Apr 7, 2010 | 09:52 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 89 caprice cop car motor in an rs? or a really fancy lawn ornament?
The '89 Police Caprice engine was nothing special. Just the same 210-hp 350 used in the fullsize pickups, complete with swirl-port heads. swirl ports are not performance heads. Still, just the rust-free, never-crashed (I assume?) shell is worth $500.
Old Apr 8, 2010 | 02:54 PM
3rdGenSuperman's Avatar
Car: 1983 Camaro Z28
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
from what I can see the caprice came in the 305 v-8 up till 1991, the police package was the only one with the 350 as far as caprice go. Also 1988 was with a 4bbr and 89 went to TBI. I can't find the engine code to look for the caprice but if it's a 350 and fuel TBI it's a good chance he's right. SOOOO what does that mean?
the police package engines were rated at 210hp the IROCs were rate 230 or 240 hp
so your not losing to much, and way more horses than the 6cyl or even the LO3 5.0, look in the block and if you see LO3 it would probably be the stock engine, either way it's worth at least $500 so your good there.
If the body is straight and you already have a 350 in it, then your off to a good start. Just clean it up hi-perf the engine an you've got a solid platform. You have a few options for the engine. Water pumps are pretty cheap and easy to throw in. Easiest would be to put a 4bbl on it, then you can run with very little electrics and computer work.
however make sure and look that engine over really well if the waterpump went it may have some problems from overheating.
Old Apr 9, 2010 | 12:22 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
it should say 5.0 or 5.7 on the back of the block. if the H2O pump is leaking it may have ran hot and fried the engine.
jhawkeye
May 25, 2022 06:33 PM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
matthew911
Aug 12, 2015 09:38 AM
