What do you think about THIS?
Old Apr 19, 2010 | 08:39 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I found a rebuilt roller 350 short block, with new flat top hyp. pistons, LT-1 roller cam with lifters, freshly ground crank, and new bearings and oil pump for $695.00.
I think I should grab that right quick!
What do you guys think?
Old Apr 19, 2010 | 09:54 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: What do you think about THIS?
maybe. Does it come with any guarantee?
Old Apr 19, 2010 | 10:29 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
No guarantee...private seller...and the pistons aren't installed, but they're new.
It seems like a nice deal.
Old Apr 19, 2010 | 10:37 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It sounds good IF you can check the bearings. Anything they won't let you check is guaranteed bad. If they say go ahead and check, then start to do so, and pay more attention to their faces than the parts. If they were bluffing, you'll see their anxiety easier than you'll spot any bad parts.
