help...electirc fan hookup for my 1989 firebird
Old Apr 17, 2010 | 07:24 PM
89 350 chicken's Avatar
Car: 1989 firebird
Engine: Carb Chevy 350
Transmission: turbo 350
Axle/Gears: 3.75
i just bought a 1989 firebird...originaly came with a 2.8....the first person to put a v8 in it just cut the computer out left all other wires
A couple of friends of mine had the car and put a 327 vette motor in it for a while...they decided to put that motor in a 1976 Monte Carlo.... and were going to junk the firebird.
well now to my problem
i got the car and just got the 350 out of the Monte Carlo.
well everything is running fine....except i don't know where to hook the electric fan up at...the last people to have the car had it hooked up to...if i am not mistaken a gauge relay or something....because we got the fan hooked up and when it blew it poped the gauge fuse....so where is an alternate to hook this up at?
i am at a lose....
Old Apr 17, 2010 | 07:32 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: help...electirc fan hookup for my 1989 firebird
I'd just get a sensor and relay to hook it up. Check out summit, they have lots of kits.
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Buy a temp sensor switch kit. It will come with a sensor for the motor, wires, and a relay and instructions on how to wire it.
185/170 for 180 Stat kits
Single Fan
Dual Fan
200/185 for 195 Stat kits
Single Fan
Dual Fan
Old Apr 17, 2010 | 07:39 PM
Car: 1989 firebird
Axle/Gears: 3.75
thanks ill look into it....tough lacking in money atm heh...any other way to get it hooked up say...from an acessory wire or something...to come on with the key?
Old Apr 17, 2010 | 07:44 PM
Zepher's Avatar
you can wire it to the Ignition, but it has to go through a relay.
Relay is a must otherwise you risk the wiring catching on fire.
One of my friends wired the fan straight to a switch on the dash and the wire almost caught fire. It got so hot that it melted the hood release cable since it was right next to it.
It was not fun trying to pop the hood open from underneath the car.
Old Apr 17, 2010 | 07:49 PM
Car: 1989 firebird
Axle/Gears: 3.75
yea i had the fan hooked to a relay (Gauge?) and the port i hooked it in stoped working...all the other parts still work...and if you overload it it pops my gauge fuse lol..
so trying to figure out another relay or something to hook 2
ignition relay ey? where can i find it...my first 3rd gen heh
Old Apr 17, 2010 | 08:05 PM
Zepher's Avatar
Go to the auto parts store and buy a relay probably be 5-15 bucks.
Do you know how to read a wiring diagram?
http://www.allfordmustangs.com/forum...-ok-wiring.jpg
In the above Diagram, you will make a few changes.
Disregard the Temp Switch.
Battery + goes to 30
Battery - goes to 86
Battery - goes to Fan -
Ignition Power goes to 85
Fan + goes to 87
Wires to 87 and 30 and both fan wires need to be at least 12 Gauge
Wires to 86 and 85 can be as small as 18 Gauge, but 12 Gauge will be fine as well.
Old Apr 17, 2010 | 08:06 PM
Car: 1989 firebird
Axle/Gears: 3.75
Thanks ill get to it and post with results
Old Apr 19, 2010 | 09:16 PM
sjgrimsley's Avatar
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
How's that wiring coming along?
Old Apr 19, 2010 | 11:05 PM
Car: 1989 firebird
Axle/Gears: 3.75
just got it fixed today..works great...one last project to do...stabalizer bar O_O lol bushing in it is breaking apart..bleh
Glowsock
Jul 24, 2025 03:15 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Linson
Aug 31, 2015 04:52 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
kyleb24
Aug 15, 2015 08:24 AM
