Quick question about lt1 head swap on 350
Old Apr 27, 2010 | 11:23 PM
derockz28's Avatar
Car: 1985 z28 90 VW Jetta ,90 VW Corrado
Axle/Gears: 4.11
Hello all, I'm preparing a build to go into my camaro. I building a 383 and am putting lt1 heads on it. I plan to run an intake manifold and a holley. My question is since I need to run a manifold specific for those heads, is that manifold any taller than the one on my car now? I plan on running the tallest one possible but I find it very difficult to search for this topic.
I'm sure this has been answered once or twice before but I cant find the answers I need on search, can anyone answer this fast? There is a manifold for sale locally, its an air gapper and that the one I want.
Old Apr 28, 2010 | 12:18 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: Quick question about lt1 head swap on 350
i cant say for sure but i think that coolant passages in lt and sbc heads are different i know the coolant passages between the heads and intake are different. id look into that a little bit before running lt1 heads. if you want a cheap alum try the patriot heads. ive got a couple friends using them and they like them a lot
Old Apr 28, 2010 | 01:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Putting Gen II LT1 heads on a Gen I 350 block is an exercise in machine shop expense (and that's assuming they know what to do).
A set of Vortec type heads with corresponding intake manifold will give you all of the benefits of the LT1 heads with none of the machining expense.
Old Apr 29, 2010 | 11:34 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
and noone has ever cast a carbureted air gap manifold for true LTx heads.
midge54
Dec 27, 2019 04:14 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
