4L60E question
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
4L60E question
I can't find an answer (I have searched) as to whether or not the 4L60e will bolt into our cars using the stock crossmember.
I've read that it bolts right in, and I've read that it needs a modified or new crossmember.
What's the answer guys?
Thanks to someone who knows the answer.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
re: 4L60E question
Bolts right in if you use the right one. Reason I say that is I'm not familiar with the later ones. Mine is a 1995 version. In my installation I used the tail housing from my 700R4 in order to retain the torque arm mount. Depending on what computer you use to control the 4L60E you may or may not have a speedometer issue to deal with. I was able to overcome that.
Transmission: 4L80E/4L80E
Unless the bellhousing bolts onto the transmission case, it will bolt in with the stock crossmember.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
C409
Sep 1, 2015 03:42 PM
