Fast Burn Heads torque specs
Old May 28, 2010 | 10:07 PM
bullzz's Avatar
Car: 1984 Trans Am, 2003 Z06 Vette
Engine: zz383
Axle/Gears: 9" moser 3.70
Does anyone know the torque spec for the rocker nut on a GM aluminum fast burn head (from zz383 crate engine)?
Old May 28, 2010 | 10:14 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Fast Burn Heads torque specs
there isn't one. it doesn't work that way. With the one you're adjusting on the base of the lobe, spin the pushrod with the thumb and finger of one hand while turning the tool with the other. When you begin to feel drag on the pushrod, that's zero lash, from there turn the nut another 180 degrees. Then move on to the next one.
Old May 28, 2010 | 10:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The Chev adjustable valve train has no torque on the rocker nut. The rocker nut and ball inside the rocker or a full roller rocker is a pivot point that maintains an adjustable geometry between the pushrod and the valve. The rocker nut is a special pinched nut that won't back itself off.
1/2 to 3/4 turn from zero lash. Don't readjust after that because the pushrod will be able to spin again once the lifter bleeds down. The 1/2 to 3/4 turn from zero lash is adding roughly .030" - .060" preload inside the lifter.
Rotate the engine by hand and do each cylinder one at a time then the piston is at TDC of that cylinder with both valves closed. Make sure it's on the compression stroke and not the exhaust stroke. The exhaust stroke will have a slight valve overlap.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
TreDeClaw
Jun 22, 2021 08:21 PM
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
