305 to 350 swap
Old May 29, 2010 | 12:10 AM
slangdon's Avatar
Car: 1986 Z28 Camaro
Engine: 5.7L 350
305 to 350 swap
My son has 1986 Z28 Camaro. We want to swap out his 305 with a 350. This is the first time we have ever done anything like this, its a learning process for the both of us. Money is a factor since my son pays for most everything, it's his car, but I'll help him if needed. Anyway, can we use the same transmission off the 305 and bolt it on to the 350 and if so what if any modifications do we need to do? Thanks in advance.
Old May 29, 2010 | 12:23 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 to 350 swap
trans itself isn't much of an issue. But if you use a pre-'86 350, you'll need to change the flywheel or flexplate. And if yours is a T5, you have to stay with a 153 tooth flywheel.
Old May 29, 2010 | 09:13 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: 305 to 350 swap
It's pretty strait forward, you can use everything off the 305 if you'd like to.
Old May 29, 2010 | 05:58 PM
slangdon's Avatar
Engine: 5.7L 350
Re: 305 to 350 swap
Thanks Atilla the Fun and zraffz. This is our first time doing this and wanted to know before getting in to dep. Thanks for the replys.
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
