Rebuilding 400sbc need feedback
Old May 29, 2010 | 09:42 PM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Transmission: 700R4 lookin for shift kit
Axle/Gears: 3.23???
400sbc +.30= 406ci
bottom end balanced,
this is what i want...
64cc Vortec heads with .600lift
Lunati Flat Tappet Hy Cam 504/525 lift
Performer RPM Vortec intake
800cfm thunder series carb
1:6 ratio full rocker rollers
or
TRICK FLOW TOP END KIT (FOLLOW LINK PLEASE)
http://www.summitracing.com/parts/TFS-K314-490-440/
ALSO I WANT TO REMOVE THE AC AND ADD A V-BELT, AND I NEED HELPING PICK OUT A STALL CONVERTER.... EVERYTHING HELPS, THANKS IN ADVANCE
Old May 29, 2010 | 10:01 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Rebuilding 400sbc need feedback
better the TFS kit than the Vortecs. They're fine for getting a 383 to 450 hp at 5600 rpm, but your choice of cam, plus your alternative, show you're wanting more than that. Look at post 8 of this thread: https://www.thirdgen.org/forums/engi...st-builds.html
Old May 29, 2010 | 10:10 PM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
okay nevermind, i took a look nd i do hav dished pistons. but what is the price on a setup like tht???
Old May 31, 2010 | 09:20 PM
88firebird400's Avatar
Car: 1992 chevy camaro
Engine: 5.0 TBI
Axle/Gears: 3:73 n 4th gen rear
ur using 64cc heads thats a down grade from stock 400 heads which are 76cc since u have th bottom end balance ur gonna be getting alot of your power throw your heads but they are still gonna work i have a 88 firebird and im putting my sbc 400 but since i dont have money to get it bored and rebuilt im gonna get it honed with new rings and the cam bearing with a huge cam, then im gonna upgrade my stock heads buy getting all new hardware in them with all that alone im gonna make 300 somthing hp just to show off till i get money to rebuild it
Old May 31, 2010 | 10:23 PM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
so ur saying i will get more HP out of my stock heads?
Old Jun 1, 2010 | 02:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Factory 400 heads are about the worst possible choice out there.
Old Jun 1, 2010 | 02:14 PM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
so what did he mean by saying that using the vortec heads will be a down grade from my stock heads? and what set up u recommend
Old Jun 2, 2010 | 11:14 PM
chesterfield's Avatar
Car: Pontiac
I'm always willing to defend 882s within reason, but he's mistaken.
Old Jun 2, 2010 | 11:20 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I'm confused, but the fact is, well-ported 882s don't out-perform stock Vortecs. On a 400, the Vortecs do require dished pistons or race gas.
Those are the absolute facts. And arguing can't change them.
Old Jun 3, 2010 | 01:42 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
I'm gonna back Atilla on this one. if your building a 406 then I wouldn't even consider stock 400 heads, If you need to use a set of factory heads find a set of 993, 920, 487, 442, or 441 castings from a 350 and drill the steam holes. the 882 castings although good for lowend torque will always crack in the combustion chamber when exposed to upper temps and yes the 400 block will naturally run hot unless you adress the cooling issues(they are a simple fix)
Old Jun 3, 2010 | 07:28 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
In all my years doing engines, I've never once yet seen a cracked 882 head. They're not real responsive to porting, but they're fine for everyday street cruising.
400s running hot is a simple matter of 4 things: an adequate radiator, a good water pump, a 180 thermostat with a steam hole drilled through it, and the correct additive in the water. I like RedLine Water Wetter, but Royal Purple also makes something similar.
Once the temps stop dropping below 32, drain ALL the antifreeze (that's why there are plugs in the sides of your block) and switch to water with additive until 5-7 months later they once again dip below 32.
Old Jun 3, 2010 | 08:39 AM
Engine: 5.0 TBI
well ur pretty much losing power unless u get high performance heads with less youll make more hp im reusing my stock heads im getting all performance hardware in them and getting them cleaned so my motor will be all stock but im gonna make 300 to 350 hp out of it
Old Jun 3, 2010 | 08:40 AM
Engine: 5.0 TBI
their only bad if you get them ported
Old Jun 4, 2010 | 03:20 AM
Well lets rephrase the 882 head debate. If you get the older head design that was flat across the outer headbolt area except for small u shape cutout then those heads held up fine but didn't flow to well compaired to other castings listed above. If you get the newer design that dips between every other headbolt for about 1.5 inch length those are the heads that crack in the combustion chambers because of poorer casting design. the newer design is what gave the 882's a bad name.
Old Jun 7, 2010 | 01:15 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Someone told me to get 327 heads. they will produce 20-40 xtra hp. Is this true?
Old Jun 7, 2010 | 11:43 AM
five7kid's Avatar
There were one or two 327 castings that were worth a hoot. They are rare restorer items, easily outperformed by a set of Vortec heads.
Ed1LE
Sep 30, 2018 09:14 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
