Heads for a Stroker
Car: 1986 Iroc-Z
Heads for a Stroker
I am in the process of trying to buy a 383 strocker to put in a 1986 Iroc. The only thing is the heads are bad on the motor, and i was to ld that heads of a 1992 Z28 305 TPI motor would work on the strocker motor. Is this correct, and if not can anyone give me advise on some other ones that could work or would be best? Thanks for all the help i appreciate it.
Transmission: 4L80E/4L80E
They would fit, and would work. But, there are better choices out there.
More importantly, the rest of the details of your build and goals are needed. What induction are you planning on using? Is this a daily driver, street/strip, or strip-only?
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
Mickeyruder
Sep 2, 2015 02:45 PM
