T-Tops and Too much TORQUE
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
will swapping an aftermarket engine in my 1990 camaro with ttops be an issue for the ttops?? something ive heard is that most fbody's were equipped with engines like the 305 so the torque couldnt twist the frame and in turn damage the ttops..
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: T-Tops and Too much TORQUE
T-tops are surviving in some pretty serious cars. But if you're worried, you can fab up some braces that'll be hidden when the tops are on. Or if you're shooting for much more than a 502 with a small nitrous kit, just do a proper cage.
That'd probably belong in the sub-forum called "Fabrication"
Until then, subframe connectors do a world of good. And the T-tops are NOT the reason for the 305s. T-tops were available with the 350 when it returned for '87.
Car: 1990 Camaro RS
Engine: 305 TBI
Thanks Atilla, I wasn't sure what to think because i've been talking with friends about the swap and saving money..I would like to put a 383 in, so I guess subframe connectors would be a must.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I'd agree with you needing sub-cons, but up to, say, 600 horses or so, no worry about the T-tops.
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
ive had anything from 350hp to 650hp and never had a problem with the sub frame or t-tops. now ive seen a 82 with a built 396 that he beat the **** out of it, shatter a windsheild because of chassie flex.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The first year I had my car, it only had SFC and ran 14.0 in the 1/4 mile. At the start of the second season, the car ran a 12.0 and I had a roll bar installed before the next race. At the time, roll bars were required at 11.99. They're now required at 11.49.
My car now runs low 9's. Although it's been back halved and has a full cage, it still has T-tops and over the years, I've never had a problem with them.
no green
Jan 9, 2016 09:22 PM
