Upgrade Lifter and Push Rods
Old Jun 14, 2010 | 01:29 PM
Nickz28ss's Avatar
Alright im pretty sure i have a lifter tick. I have to re-due the intake manifold gasket anyways so while im doing that im gonna do the lifters and push rods. I have a 5.7 Carb.
Give me some opinions on good lifters and push rods to put in there?
Old Jun 14, 2010 | 04:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What year is the 350 block? Do you know what cam and lifters are in there now?
What heads? Before you go changing lifters and pushrods, make sure there isn't anything amiss under the valve covers such as an adjusting nut backing off, or rocker stud pulling out, or rocker damaged (I've had all three happen to me).
Also, I always had lifter tick when I adjusted my lifters 1/2 turn down. Went away completely when I adjusted them to the factory 1 turn down.
Old Jun 14, 2010 | 04:26 PM
Nickz28ss's Avatar
Re: Upgrade Lifter and Push Rods
well i look at it all again, nothing seemed lose or anything, but ill double check again
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
z28guy134
Sep 1, 2015 11:50 PM
