305 swap to a 327
Old Jun 18, 2010 | 01:17 PM
OleRed85's Avatar
Car: 1985 Z-28
Engine: 327 bored 40 over
Transmission: 700 R-4
305 swap to a 327
I just swapped my old wore out 305 for a 327. I had the block bored 40 over with flat top pistons, replaced the crank with a 10 under steel crank, replaced the old intake with a eldelbrock preformer and a eldelbrock 650 carb. I also replaced the old exhaust with Hedman headers and true dual exhuast. I am wondering what kind of hp and torque I am going to produce. Im hoping more 350+
Old Jun 20, 2010 | 01:38 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: 305 swap to a 327
what cyinder heads/cam combo are you running?
fyi, performer intake is a stock replacement manifold...and you went backwards going to the edelbrock carb.
hp...based on info i know...maybe 280 flywheel hp
Old Jun 21, 2010 | 09:50 PM
OleRed85's Avatar
Car: 1985 Z-28
I am running 305 416 heads with i've had them port and polished I have a 282 duration .534 .555 lift cam doug herbert but I have to get ride of that i can't get it to idle in drive and don't have the money for a 3000 rpm stall converter. I am running an electric fuel pump so I can boost the gas going to the carb I know it's a stock replacement manifold but I was on a tight budget building this motor i wanted 350 at the fly wheel any secrets to helping that with what I have and what cam shouldI go with?
xkingcodex
Feb 12, 2020 07:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
