will this work before i buy it! NEED HELP!
Car: 91 camaroRS
Engine: 350 vortec
Transmission: 700r
ok doing a 350 motor swap from a 305 in a 91 camaro rs everything stcok still on the car. The part number for the motor i want is 12530282 thats gm direct! Got all the cash in hand and before i make this purchase just wanted to make sure it will fit & work in my camaro because some we sites have been telling it wont! also i know that i will have to change the intake but can i use the distributor & other things from off of the 305?????
Transmission: 4L80E/4L80E
I don't think it will work until after you buy it. . .
It has Vortec heads, so you will need a Vortec-type intake (which you apparently know), but otherwise everything from your 305 will fit.
From your username, I assume you have a '91 305 RS TBI. If the exhaust is stock, it is restrictive to a 305, and will be even worse with a 350. The TBI computer calibration will most likely need to be modified to get it to run properly.
But, if you just put on a Vortec TBI intake and bolt the engine in, it will at least run.
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Re: will this work before i buy it! NEED HELP!
dammit, i had that joke planned before i even got to the thread and now you stole it from me!!!!
ya, lets just say im a little bored
but anyhow i think you pretty much got all the info down that you need. and so yes it will work.
Car: 91 camaroRS
Engine: 350 vortec
Transmission: 700r
thanks dude just wanted to make sure before i spent my money!......will i need a to change the whole exhaust?
That would be best. Headers, cat, and cat-back for the '86-'90 TPI single cat application will do you well.
Car: 91 camaroRS
Engine: 350 vortec
Transmission: 700r
do you know of any complete exhaust systems i can buy with headers and everything?
hectre13
Aug 26, 2015 08:17 AM
mustangman65_79
Aug 11, 2015 03:17 PM
