400 SBC
Old Jul 9, 2010 | 11:55 AM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
400 SBC
ok, ive gotten my hands on a 400 SBC, I want to build and put in my 85 this winter, it currently has an 87 MAF TPI on it's 305.
I want to hear from people who have DONE this, on what a good combo is. I do not want to make JUST 300 hp, but I don't want to go carb.
What options do I have to make this work and slam me into the seat with raw power??
I would LIKE to preserve the TPI if I can, Also, I do have a T-5, I want to stay manual, so what trans options do I have that can stand up to this thing (5 spd or more)
I have searched, and every thread turns into a heated debate with skewed info every where, lets attempt to not do that please?
Old Jul 9, 2010 | 06:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 400 SBC
Depends what you want to do with it. You could just drop it in and run it like it is. To make any sort of performance, the first thing you need to do is change the heads. If you're going to make a lot of performance, the cast crank and stock rods/rod bolts need to go.
That doesn't leave much left over. With all the aftermarket choices available, it might be cheaper to just buy a new 400/406 or 434 built the way you want it.
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
