5 speed manual to automatic
Hi all,
Looking for a little help, I have a 1989 RS with a 2.8l and 5 speed manual transmission I would like to pull the motor and trani out and put a 2.8 l with auto in it. Is this something I can do and if so what challengages will I run into. I am racing this car and we must have automatic transmissions. Thanks
Transmission: 4L80E/4L80E
Sure, it can be done. Since members are pulling V6's all the time for V8's, you might even come across someone who would give you the stuff.
Is there a requirement for the type of automatic transmission? If you go with the '83-up TH700, you should probably get a computer for auto trans as well.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
