383 build
Car: 88' Z
Engine: 350 .60 over
Transmission: W/C T5
383 build
one simple question do i have to bore the 350 .030" over. With the added stroke of the 400 crank and the standard bore of the 350 (4") it should make it a 383 ? someone told me you have to bore it .030" over but wouldnt that make it a 378 ?
Transmission: 4L80E/4L80E
Check your math. What are you using for the value of pi? Using 3.14159 (which contains sufficient significant digits), 4.030" bore with 3.75" stroke in 8 cylinders produces 382.6668677325 cubic inches.
My Palm calculator has a preloaded value for pi of 3.1415926535898. Using that, it comes out to 382.66719095765 cubic inches.
Either way, rounding to 3 significant digits produces 383 cubic inches.
On a 4.000" bore with 3.75" stroke, 8 cylinders, it comes out to 3.76.991 cubic inches - rounds off to 377 cid.
(Formula: bore squared, divided by 4, times pi, times stroke, times number of cylinders)
Right, the 6.2832 is pi times 2 (the "2" being 8 divided by 4). Oh, and that's rounded off.
But that's like giving a fish vs. teaching to fish.
Now, if we really want to teach to fish, the volume of a "cylinder" is the area of the base times the height. The base equates to the bore, and the height to stroke. And, we all remember that the area of a circle is pi times the radius squared (the radius being half the diameter, and D/2 squared is diameter squared divided by 4 - remember the "4" from the first line?).
Junior high math applied to the real world - and we all hated word problems on math tests.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 build
YOu dont have to over bore it if you use the GM 3.80" stroke and dont deck the block (Well its 382" technically...), but thats 1100 bucks and not worth it.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 383 build
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Re: 383 build
heres the easy way
bore x bore x stroke x .7854 x (number of cylinders)= cu in of displacement
4.0x4.0x3.75x.7854x8=376.992
Blamo!
Blamo!
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Car: 1992 Camaro RS
Transmission: WC T5
Re: 383 build
hahaha man this is the easy stuff! Wait until you are trying to figure compression height for piston to valve clearance. Better break out the notebook. Hit the link for ultra easy version
http://www.csgnetwork.com/cubicinchdispcalc.html
This website has some extremely useful java calculators.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Andrew Prakash
Sep 8, 2015 11:48 AM
