How much power? 12530282 Crate
Car: 1983 Z28
TPI bolted to a Vortec crate engine # 12530282 with Hot cam? Looking for something reliable with decent power.
Transmission: 4L80E/4L80E
That engine can't take the Hot Cam lift, even with 1.5:1 rockers. At a minimum, you're going to need new valve springs, and probably have to pull the heads to have the top of the guides cut for more valve travel.
Scoggin-Dickey already did the groundwork; upgraded the Vortec heads for the lift, LT4 Hot Cam with 1.6:1 roller rockers, Vortec TPI base, aftermarket runners, 52mm TB, long tube headers, and made 360 HP (gross flywheel HP).
http://sdparts.com/details/scoggin-d...nter/sd360vtpi Reliable with decent power. You need to add the runners, TB, and headers (and 22 lb injectors if your TPI doesn't have them already).
theshackle
Sep 17, 2020 08:26 AM
sailtexas186548
Aug 24, 2015 10:11 PM
