fuel system swap for 91
Old Aug 4, 2010 | 12:18 PM
jburton50's Avatar
ok, idk where to post this, but im still having problems with my car not starting and im to the point where im wondering if its possible to do a fuel system swap to eliminate all the problems. i have a 327 thats been pretty toughend up, and im not sure why my car wont turn over or start or anything, but since this 327 is from the 60's, im wonderin how much hassle it would be for me to go ahead and convert the car from the intake fuel pump to a mechanical fuel pump. i have tried bypassing vats, i dont even know why the car wont start now. when i turn the key i get no click. no engine light, just the noise tellin me the keys in the switch. i had cut the rad. wires to run a switch, then decided to put them back like they were (they are right hooked up correctly), and still nothin, so idk what else to do.
to sum it up my questions are, is there anything else i need to check b4 i start looking into simplyfy everything.
Old Aug 4, 2010 | 03:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The fuel system won't have anything to do with the engine not turning over.
You need to track down what has power and what doesn't. Somewhere in your start system you aren't getting power to the starter. Could be VATS, could be neutral safety switch, could be ignition switch, could be the starter, could be a power wire issue (blown fusible link, wire not connected, etc.).
Old Aug 4, 2010 | 03:23 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fuel system swap for 91
Did you go through this:
http://www.austinthirdgen.org/index.php?pid=38
Old Aug 7, 2010 | 02:46 AM
jburton50's Avatar
no i did not try that^ i will def will though..
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
