The 383 stroker crate engines
Old Aug 6, 2010 | 09:36 PM
George90GTA's Avatar
Car: 1990 GTA
Engine: 355
Does blueprint make a TPI compatible 383 engine?? If so does anyone have the info and/or link to the P#/specs?
Thanks.
PS- If so, would it be better to use a turbo 400 instead of the 700r4?
Old Aug 7, 2010 | 03:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: The 383 stroker crate engines
What do you mean by "TPI compatible"?
Old Aug 7, 2010 | 07:55 PM
Car: 1990 GTA
Engine: 355
There were at least 4 engines. I read that a couple engines were non EGR. Another engine was generation 1. I am not sure if any of that matters to add my 1990 TPI from my stock 5.7. Does a vortec head work with my TPI? I thought vortec heads were for the 1996 and up engines... I'm kinda confused. Please help. Thanks!
Old Aug 7, 2010 | 09:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Non-EGR most likely means that the heads don't have exhaust crossovers. This is only a problem if you want to keep your EGR working. Your 1990 5.7 is a Generation I SBC, so no problems there. Vortec heads are for Generation I blocks, but won't fit your TPI unless you use a Vortec TPI base.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
