Need Help connecting a hose? Not sure where it goes.
Old Aug 8, 2010 | 09:44 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
1991 Camaro RS 5.0 305 TBI Auto
Okay i found a hose that is completely disconnected from everything and its sucking in air.(hiss noise)
I Suspect that the hose goes somewhere on the EGR Vacuum solenoid on top of the canister purge? but i am not completely sure.
Here are the pictures, if anyone could reply with a picture of their set up it would help a ton any info is appreciated.
Old Aug 8, 2010 | 10:23 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: Need Help connecting a hose? Not sure where it goes.
did your car originally have cruise control and was it removed?
Old Aug 9, 2010 | 12:10 AM
Car: 1986 Iroc-Z
Engine: 355
Nope not that i know of.
Never seen a switch for it on the car or anything either.
Old Aug 9, 2010 | 01:18 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There are 3 things in that area that take a vacuum line.
1) the evap canister in your pic
2) cruise control - if your car had it, the switches are on the turn signal stalk
3) the vacuum ball, or 'orb' - it's under the evap canister - you have to get to it from underneath the car - remove the plastic piece under there and you'll see the ball - it's about 7-8 inches around and black - it 'stores' vacuum for your heater controls which use vacuum to open/shut the doors to change which vent air blows out of.
Regardless of anything, you either need to get it connected where it's supposed to go, or get it plugged, as it's a vacuum leak that will make the car run poorly. You can just stick a screw in the end to seal it until you get time to find it's 'home'.
Old Aug 9, 2010 | 02:10 AM
Car: 1986 Iroc-Z
Engine: 355
Thanks man im gona look into that tomorrow even though i still gota find the spot where it goes connected but im gonna seal it if i really cant find its home.
racereese
Oct 10, 2015 09:39 PM
Stryker412
Sep 20, 2015 06:59 PM
steimel94
Sep 20, 2015 12:46 PM
st.evel07
Sep 19, 2015 09:24 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
