distributor wiring.......
Old Aug 16, 2010 | 07:59 PM
allred's Avatar
Car: 1986 IROC-Z
Axle/Gears: 10 bolt w/ 3.73's
Okay so I'm in the middle of my 305 tpi to 350 carb swap. After reading the Tech article 100 times I have but one question. The car has a 4 wire distributor harness that plugs into the tpi distributor, I know I plug my tac wire on the new ACCEL distributor to the white wire in the harness. Where the heck do I connect the battery+ wire? Can I connect it to one of the other 3 wires in the tpi wiring harness?
Old Aug 16, 2010 | 10:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: distributor wiring.......
Should be a pink wire, IIRC.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
