help 383??? opinions for next step
Old Aug 25, 2010 | 12:56 PM
383camaro1991's Avatar
I have a 383 that is getting near the end of its life and i want to either rebuild the 383 i have in it now which is just an older high nickel block or buy a new shortblock
which would be more cost effective?
Old Aug 25, 2010 | 01:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: help 383??? opinions for next step
Costs probably won't be that much different either way, assuming your existing components are in good shape.
Old Aug 25, 2010 | 01:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yeah how tired is it? Just need a rebore/piston package and new bearings and call it a day? Or would you want to do rods/pistons/crank?
Does the block have a rebore left in it?
If you bought a new shortblock would it be a aftermarket block setup? IF so go with more inches.
Old Aug 26, 2010 | 05:24 PM
Guest
Guest
Posts: n/a
JE will do ya 70 and 80 over pistons, dunno what power level an 80-over block is safe to.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
LT1Formula
Oct 8, 2015 08:34 PM
