350 Build, Critique my proposed build
Old Sep 1, 2010 | 09:41 PM
rspain85's Avatar
Here's what I have in mind as of the moment. I already have SOME of this list, but not everything. Been trying to decide on a parts list for a couple weeks and this is where i'm at so far. Anyone have any suggestions or experience with similar setups?
350 .40 Over
Stock Cast Crank
Stock Cast Rods with Wrist Pin Hole Drilled
Hyperutectic Flat Top Pistons with Moly Rings File Fitted
ARP Main Bolts
ARP Rod Bolts
ARP Head Bolts
#906 Casting Vortec Heads with Spring Retainer "Ghetto Grind" for seal clearance
Lunati 73943 Valve Springs
Lunati Voodoo 60103 Cam -
Lift: .489''/.504''
Duration: 268°/276°
RPM Range: 1800-6200
Stock 1.5 Ratio Steel Rockers
Holley Stealth Ram Intake with Fuel Rails and AFPR
24# Injectors
Stock 48mm Throttle Body
Long Tube Headers with undecided exhaust
Megasquirt III
Old Sep 2, 2010 | 07:00 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 Build, Critique my proposed build
Stock rods are not cast. They are 1053 steel forgings.
Old Sep 2, 2010 | 03:55 PM
rspain85's Avatar
Well judging by the casting marks on the sides of the rod, i would say they are CAST, but thanks for the useless comment
Old Sep 4, 2010 | 12:25 AM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
wow,you come with that attitude asking for opinions?
Old Sep 12, 2010 | 01:05 AM
FunkyPup's Avatar
This.
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
