almost done need a little more help!
Old Sep 2, 2010 | 11:04 PM
ap91rs350's Avatar
Car: 91 camaroRS
Engine: 350 vortec
Transmission: 700r
Ok got my GM crate motor in part# 12530282 intake part #12496821. now iam having problems making everything fit. ounce i put my intake on i noticed that everything does not fit exactuly the right way like i was told before on this web site. If anyone has done this swap the same way i have could you please give me some info on where all the sensors will go & how do i get the throttle linkage & bracket to line up because its seems like its off a little bit & wont fit! if you have any pictures please post so i can see what everything is supposed to look because iam CONFUSED!
Old Sep 9, 2010 | 04:43 PM
Guest
Guest
Posts: n/a
Re: almost done need a little more help!
You shouldn't be having any trouble at all with the throttle linkage and bracket. That attaches to the plenum, and that should be the same one you had before buying the engine and lower intake. The new lower and new engine don't move the plenum any.
Even if you replaced the motor mounts, the throttle cable should still reach just fine.
Maybe you should post us some pics of what's wrong?
