tbi 305 to carb 454 swap
Old Sep 7, 2010 | 07:53 PM
Jake88maro's Avatar
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
hey guys i just pulled the worn out 305 out my 88 camaro. and i was just wodering what can i do to eliminate the old tbi wiring?
Old Sep 7, 2010 | 10:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: tbi 305 to carb 454 swap
Depends what you want to keep and use? If you want the gauges to still work, you need to keep the sensor wires. The TBI wires can be cut off if you don't want to just leave them in the harness. The ECM doesn't care if injectors are connected to the harness or not.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Fast355
Dec 2, 2016 06:33 PM
tero
Aug 6, 2015 06:34 PM
