Problem Starting??
Old Sep 8, 2010 | 06:04 PM
Nickz28ss's Avatar
Problem Starting??
Sometimes my car will start, sometimes it wont. I have a 86 IROC with a swapped 350 carb. Battery and Alternator tested fine and show it works. Just Replaced the Starter and still the problem is there. When it doesn't start, it still shows full battery and everything turns on and works with the key at run, but when i go to turn it over there's nothing. No click or anything! I can jump the starter and it spins. So im lost. I haven't found a rhyme or reason on how i can get it to fire up. After messing around with everything it will finally start.
Any ideas. Is there a relay somewhere or something.
Old Sep 8, 2010 | 06:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Problem Starting??
Might be neutral safety switch - if it's an auto, it's on the shifter, if it's a manual, it's on the clutch. I know the auto is adjustable, might try adjusting it before replacing it.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
