probably the same ol question...tbi to tpi
Old Sep 9, 2010 | 04:33 PM
fcarpenter's Avatar
ok, i've searched but cant find what im looking for so here goes..i have a 91 rs 305 tbi..want to swap with 350 tpi..donor motor is long block with intake..has tpi system including sensors/maf/ecm/harness...my question is..what else will i need for this conversion...any input is greatly appreciated.
Last edited by fcarpenter; Sep 9, 2010 at 05:12 PM. Reason: added info....the tpi engine is from an 87 bird
Old Sep 9, 2010 | 05:59 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: probably the same ol question...tbi to tpi
just make sure youve got the complete setup, and then swap the harness with the donor one, its pretty cut and dry, i think you MIGHT need a different flywheel if its a manual, flexplates should swap over, if you can get it with the motor id do it
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
