LeMons Camaro Build
Old Sep 17, 2010 | 08:07 PM
LeMons Monty's Avatar
Car: 1989 Camaro
Engine: 1995 LT1
Axle/Gears: 3.23 Auburn
LeMons Camaro Build
Hey all,
I'm a member of a team the runs a 1989 Camaro in the 24 Hours of LeMons races. (http://www.24hoursoflemons.com if you don't already know.)
We abused the hell out of our old 305 TBI last race and we now face a decision. We can either repair what we've got or take the plunge on a 350. I'd like to do the 350, but I'm on a very tight budget. We can't spend more than $325 on the car before the next race to comply with the whole $500 dollar car thing. As a result, I don't think we can afford to convert to TPI. Therefore I have some questions:
What vehicles would make suitable donors for 350 TBI engines?
Would a 350 make a stock 3rd gen 5-speed transmission cry tears of blood?
If not, what would I have to do to a 350 TBI to make it fit my crappy transmission?
Do I need to do anything special to bolt a 350 TBI in there or will my current fuel setup, etc. work with it?
If I found a 4th gen drive train or parts of it, would it bolt up?
Thanks in advance.
Pictures of of our devil Camaro on the track are here: http://s83.photobucket.com/albums/j317/emattson1/
-Monty
Old Sep 17, 2010 | 09:43 PM
Guest
Guest
Posts: n/a
Re: LeMons Camaro Build
If you just bolt in a stock LO5, it should be easy, and survive. The '88-'92 LO5 found in C1500 pickups was rated 210 HP at 4000 rpm, and 300 ft-lbs, while your LO3 was rated 170 HP. So it'd be a small improvement.
If you were doing this near a pull-your-part salvage yard, then fitting it in your budget would be easy. Just get the long-block, the injectors, and the computer. That's all you need. You can keep your LO3 flywheel, starter, and everything else.
Your T5 is already the best stock version.
Old Sep 17, 2010 | 10:29 PM
Pocket's Avatar
Car: 91 Trans Am
LO5 from a pickup like posted with the old TBI harness and a tune or find a cheap quadrajet and carb it
Old Sep 17, 2010 | 10:42 PM
Stephen's Avatar
Car: 87 GTA
Avoid clutch dumps & the WC(88+, iirc) T5s live quite happy behind 350s.
For a stronger 4th gen part...Grab a full rear axle. Bigger/better rear brakes (if you need stopping power) & a stronger/better rear differential/posi section.
Old Sep 17, 2010 | 11:38 PM
Car: 1989 Camaro
Engine: 1995 LT1
K, so '88-'92 or so 350 TBI truck engine.
Will I need a different bell housing on the transmission?
Will a gen 4 rear end bolt up or will I need to change something to mate it to the existing drive shaft?
Old Sep 18, 2010 | 12:11 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
i run a wct5 behind mine. no bellhousing change just a 153 tooth 1piece rear main fly wheel. like 50$ at shucks,
got mine out of a 91 chevy 4x4. then put the 416 heads (194's/150's valves) ported polished. then typital cam lifters,intake,timing chain, all new gaskets.
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
86camaroman201
Aug 19, 2015 04:52 PM
GVMV
Aug 16, 2015 08:01 PM
sreZ28
Aug 14, 2015 07:48 PM
