Moving on from 350" to a 400" SBC...
Old Sep 22, 2010 | 12:13 AM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
i just recently scored a MINT 30k mile 2 bolt 400 from a motorhome that runs like a swiss watch...
Unsure right now what im going to do as far as heads go...but i may just swap my HSR/vortec heads onto it, along with the BBS single setup..
old 350's coming out next week, so as usual, ill flood you guys with pics ahah.
Old Sep 22, 2010 | 06:11 AM
Re: Moving on from 350" to a 400" SBC...
If you're running the 12.8" flywheel, have the extra starter bolt hole drilled BEFORE you drop the motor in and discover your starter won't bolt up to it.
Here's the one I had to drill in a 400 block I was using for a while.
It needs to be fairly precise; not easy to attain while laying on your back cursing at the exhaust.
Old Sep 22, 2010 | 07:05 AM
InjectorsPlus's Avatar
Former Sponsor
NICE SCORE!
400 blocks are getting harder to find, this is a keeper. Should be good to 800HP or so.
Old Sep 22, 2010 | 07:38 AM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
lUCKY! me want REAL bad!
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
gord327
Oct 3, 2015 01:25 PM
Fanatic1074
Oct 2, 2015 03:47 PM
