3.1 to 4.3 carb swap help
Old Sep 27, 2010 | 08:32 PM
jeffs92rs's Avatar
hi i have a 1992 rs and im thinking about swapping a 4.3 in to it from a astro van what will work and what problems can i expect thanks jeff it has a 3.1 in it now i am going to use the complete drive train from the van(motor transmission exaust) will this work?
Old Sep 27, 2010 | 11:31 PM
AmorgetRS's Avatar
Re: 3.1 to 4.3 carb swap help
Do a quick search... some say great idea, others say all the work of a V8 without the 2 extra cylinders. I'm in the latter.
Old Oct 10, 2010 | 12:08 AM
ATOMIC's Avatar
Car: 88 gta (black/black wheels)
Engine: 350tpi
Transmission: 700r
Axle/Gears: 3.27 posi
there are a few things to check.
the mounts should be easy because the astro 4.3, unlike the s-10 4.3,
uses the same 2.8l style mounts as the camaro and 2.8 s-truck.
trans mount, you will have to swap the fbody tailhousing onto the astro trans. direct fit.
what year is the astro?
is it tbi or vortec? witch vortec?
i assume your camaro is multi port?
you might have to change the alt/ac/power steering brackets on the front of the
motor to a set from a camaro / fb or caprice.
the truck alt and ac comp brackets position the accessories about 2 inches higher than the car parts.
so you might not be able to close the hood without changing them to car spec.
the astro might have a hydroboost system on it, that would be a great and easy swap because you get
FULLY three times the brake boost compared to the best vac brake booster available.
the truck harness is about 2 feet shorter than the camaro parts but you have plenty
of room to drill a new hole under the edge of the ac box at the trans tunnel.
the exhaust manifolds fit fine and the power steering lines hook right up with little
to no bending.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
