engine/transmission compatibility
Car: 1988 Base Coupe
Axle/Gears: 9 bolt w/ disk brakes - 3.70
ok, this might sound complicated but ill explain the best i can.
my camaro is a 305 auto, and i have been wanting to swap in a 5-speed, so i have been looking for a donner car.
a friend of mine knows ive been looking and his dad has a scraping business, so he called me up and said he has an early 80's camaro there to be scrapped and wondered if i wanted it.
turns out the car is a base coupe with a straight 4 and came factory with a 4-speed, but the guy they got it from said he swapped in a 5-speed
my question is, does anyone know what the bolt patern for the inline 4 is?
I am trying to figure out if the guy swapped in a 5-speed from a v6 or a v8, because if it is a 5-speed from a v8 i want it.
another question i might as well ask here. is all the clutch hardware the same regardless of engine and tranny? slave cylinder, linkage, ect...
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: engine/transmission compatibility
even if i had to change the bell housing i can deal with that, i was more concerned about the tolerances of the transmission, thanks guys, this is why i ask the pros
