Will this 350 mount?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Will this 350 mount?
The mounting provisions on the SBCs are the same, so they're all interchangeable. That block has the dipstick tube on the drivers side, so you might need to tweak it a little to clear stock manifolds if you're not using headers. It's also a one piece rear main seal block, so you'd need to change the flywheel.
Transmission: 4L80E/4L80E
The original '86 engine is 1-piece RMS; the 010 is 2-piece RMS. (will need to change the flexplate/flywheel)
Eric-86sc
Aug 24, 2015 09:01 PM
