bottom line on bolting a t56 to 454
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
okay so i've been looking for days now and apparently theres a million different ways but what really is the best way to bolt a t56 to a 454? not looking to spend an arm and a leg but i'll consider anything from a retrofit to a new bell housing. i already have everything form my t5 stock also a 168 tooth 454 flywheel and a brand new 26 spline clutch. let me know thanks alot jake.
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: bottom line on bolting a t56 to 454
In addition to the kick *** advice you'll get here, I would suggest you visit ls1tech as well... the T-56 is a 4th gen Transmission, I'm sure someone there has already done it...
Insert hardware. Rotate clockwise.
Which T-56 do you have? What 454?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You'll need a flywheel that will accept a T56 clutch, and is 'unbalanced' for a 454. Otherwise, should bolt up pretty easy.
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Mk IV 454(two-piece rear seal) are externally balanced and requier a externally balanced flywheel or flexplate. Question is which t-56 are u using? If using a lt-1 (93-97)t-56, then your bellhousing will work assuming the clutch/pressure plate is not bigger than 11" though 10.5 is the norm. You will also have to work out the pull style slave/fork arrangment. If your using the LS1(98-02) t-56, then a new bellhousing will be needed because the bolt pattern is NOT the same as a Mk IV BBC. McCleod, Lakewood, and Quicktime all make bellhousings. IMO the Quicktime is the only way to go. There are a couple of other things to consider depending on which tranny you use, like internal/concentric slave?, driveshaft length, etc. Can't get to the 'bottom line' without certain info.
well i havent actually got the t56 yet but im lookin at both a ls1 and an lt1 which would you say was the easiest? and the cluth i have now is a 11 7/8 inch so thats why it wont fit under the t5 bell housing?
The LT1 setup is the easiest to use on a Gen 1 SBC or a BBC, because the LT1 itself so so much more similar to the Gen 1 motors than the LS engines are.
I can't recall a mfg's name, but I remember seeing a scattershield out there that will allow one to use a T56 trans with a traditional SBC/BBC clutch setup, instead of buying a conversion flywheel to use the LT1 clutch. You also get the benefit of the explosion-proof-ness of a scattershield. Might be worth looking into. I think I saw this on one of the 4thgen boards, but I can't remember which one.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
