LG4 to L98 question
Old Nov 24, 2010 | 02:01 PM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
LG4 to L98 question
I have a complete LG4 with the harness and all that came from an 86Z that I stripped (couldn't be helped). I was planning to use it in a new project, but now I have a line on a 89 L98 block and heads. Can I use the intake/carb from the LG4 on the 350 with center-bolt heads? Did some searching and it sounds like the ports might not line up. Any truth to this? TIA
Old Nov 24, 2010 | 02:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The ports line up. The center two intake mount bolts on each side are at a different angle on the later heads.
You can either buy a different intake for the '87-up application (http://www.summitracing.com/search/D...s/?Ns=Rank|Asc), or elongate the mount bolt holes in the '86 intake manifold.
Old Nov 24, 2010 | 04:05 PM
Car: 1988 IROC
Re: LG4 to L98 question
Thanks for the quick response! In keeping with the spirit of my low-budget build, I guess I'll modify the existing intake.
Old Nov 24, 2010 | 05:57 PM
five7kid's Avatar
The nice thing about the Professional Products piece is it will fit either type. It would be nice if those bushings were available as a separate kit.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
