Turbo LT1 383!
Old Nov 24, 2010 | 02:16 PM
Dr. Phil's Avatar
Car: 1987 Pontiac Firebird GTA
Engine: 383
Axle/Gears: 3.42 10 Bolt
Turbo LT1 383!
I have in my 87 bird a 383 w/ forged internals. Its an 87 roller block so it has the one piece rear main seal. I like the lt1's fuel system and its reverse cooling especially for running boost. Its going to be a few months until i start the build, but im doing my research now.
The question is, for the LT1 build, how much of my sbc internals will swap over to the lt1? I know ill have to buy some aftermarket heads again, but will the pistons/crank/accessory bracket ect swap onto an lt1? Next question, If i buy some bare trickflow heads off summit that need 2.02/1.60 valves, can i rebuild the lt1 heads using everything off my sbc heads? I have aluminum PBM heads now on my 383. I have more questions, but these are the most important ones, thanks!
Old Nov 24, 2010 | 02:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Accessory brackets won't fit.
Not sure if the Trickflow or PBM heads need special parts. If not, then your parts should fit.
Old Nov 24, 2010 | 03:37 PM
Dr. Phil's Avatar
Engine: 383
Re: Turbo LT1 383!
Alrighty, thanks for the info.
L0tuS
Oct 4, 2015 08:07 AM
sleprock
Oct 1, 2015 09:39 AM
New2Chevy
Sep 28, 2015 12:35 AM
L0tuS
Sep 4, 2015 11:16 PM
