conversion TBI to Edelbrok carburator: computer controlled distributor??
Old Dec 1, 2010 | 09:13 AM
maxpinin's Avatar
Car: pontiac firebird 88
Transmission: manual 5 speed
Hi
I'm a Pontiac Firebird 88 owner. My car was converted from TBI to a manual carburator. It was installed a 1405 Edelbrock carburetor, Edelbrock performer intake mainflow, exhaust headers edelbrock , deleted EGR catalytic converter smog pump.
But the distributor is still original, controlled by the ecm.
The car worked fine for me, is a manual 5 speed. So I would understand if it is essencial change also the distributor with a manual one.
thanks to anyone who answer!
Old Dec 1, 2010 | 09:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: conversion TBI to Edelbrok carburator: computer controlled distributor??
Yes it's essential.
Old Dec 1, 2010 | 11:26 AM
maxpinin's Avatar
I checked with the timing light at 2000 rpm, and the ignition timing moves forward. so I presume that it work fine. i write from italy and here is very difficult to find someone that knows this kind of things.
Old Dec 1, 2010 | 12:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's not fine. You're not getting enough advance, only the very small amount that's built into the distributor's limp-home mode.
Old Dec 1, 2010 | 12:55 PM
maxpinin's Avatar
thanks a lot, what kind of distributor do you suggest me? msd or else?
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
midge54
Jan 29, 2017 07:00 PM
stalkier
Aug 21, 2015 01:54 AM
