power steering not working after engine swap
Old Dec 1, 2010 | 10:53 PM
tthompson's Avatar
so i just swapped my stock 305 for a .030 over 350 everything seamed to be going fine but now i have no power steering since the swap i used the serpentine setup from my 305 for now but put on a new power steering pump (for a 305 to fit accessory brackets dont know if there was a difference anyway) anyway the fluid flows through on the high pressure hose when disconnected from the gear box (which i have also now replaced) but i still have no power steering i have let the motor idle in the driveway for at least 20 mins and test drove it to rule out air lock but still no luck any idea what the problem could be as far as i know the only electronics on the power steering system is the pressure sensor for idle bump right?
305 was tbi 350 is carb with hei dizzy ecm isn't being used for any engine control im at a loss any suggestions would help
thanks, Tim
Old Dec 1, 2010 | 11:27 PM
Drac0nic's Avatar
Re: power steering not working after engine swap
have you gone ALL the way to both locks on both sides? usually the one I have doesn't become "active" until then.
Old Dec 2, 2010 | 07:37 AM
tthompson's Avatar
yep several times even put it on jack stands and went lock to lock for a good five min straight and no luck
Old Dec 2, 2010 | 08:07 AM
TTmonteSS's Avatar
Car: 85 monte ss
Engine: 331 twin turbo
Axle/Gears: 3.73 posi 7.5"
sounds like a clog in the line some where. even a bad pump will pump something.
Jorlain
Aug 24, 2022 05:11 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
