distributor hook up 91 camaro
Old Jan 2, 2011 | 03:17 PM
firebirdton's Avatar
Car: 82 Firebird
Engine: 383 stroker
Transmission: 350 turbo
Axle/Gears: 3:73
hey guys i have a quick question for you i am swapping my 3.1 v6 for a 383 will the wiring harness from the v6 hook to the distributor on the 383 what would i have to do to make it work
thanks
Old Jan 3, 2011 | 12:14 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What distributor are you going to run in the 383?
Old Jan 3, 2011 | 07:08 PM
Car: 82 Firebird
Engine: 383 stroker
Axle/Gears: 3:73
Re: distributor hook up 91 camaro
i was thinking about a hei with vaccum advance
open to suggestions
Old Jan 4, 2011 | 02:02 PM
five7kid's Avatar
It won't hook directly to the HEI distributor, but it isn't hard to make work.
Assuming you're talking about a coil-in-cap type HEI, you'll need the pink and white wires that go to your current coil, and hook them up to the "BAT" and "TACH" terminals on the HEI, respectively. You can get an HEI connector with pigtails to accomplish this.
You'll probably have to modify and/or lengthen the wires to the alternator, and possibly the temperature gauge sender wire, and perhaps the oil pressure gauge sender wire. You shouldn't have any problems with the starter wires.
Old Jan 4, 2011 | 06:55 PM
Car: 82 Firebird
Engine: 383 stroker
Axle/Gears: 3:73
thanks i appreciate the help
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
stalkier
Aug 7, 2015 04:49 AM
