Why can't things just be easy?
Ok I am working on swapping my 305 TPI out and putting in an L98 TPI from a Corvette. The Corvette was even the same year as my Z28. Everything was going fine until I realized the bracket that mounts the AC compressor and the belt tensioner from the 305 will not mount to the L98 aluminum heads. My question is do I use the belt and pulley setup from the vett or do I have the heads machined so I can mount the bracket on them? Thanks for any help with this.
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: Why can't things just be easy?
The lower bolts that connect to the block still line up, right? I forgot what TPI acc. Brackets look like, I chucked them a long time ago. You can drill and tap the heads while in the engine bay. Use The brackets to mark your holes, drill the proper sized hole with a drill motor, use a tap to make.treads. I think the bolts are 3/8" but don't quote me. .. I wouldn't drill too deep, maybe 1/2" deep. Goodluck!!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Means nothing.
Vettes and F-Bodies have always had different setups due to different under hood clearance
Where are you missing holes?
After further investigation only one hole does not line up. So if three of the four bolt up then I am not going to worrie about the forth one.
Thanks for the help.
