84 z28 camaro?
84 z28 camaro?
I have a 84 z28 camaro and I was wonder what would be the best turbo for the car and how much money it would cost me to buy the engine is a 305 I have a 5 speed tranny and a custome exaust on the care already I also have a corvet carb and air intake that I haven't put on yet idk if that will make any diff in horse power or not?
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: 84 z28 camaro?
Running power-adders is not cheap if you want it done correctly. I guess you could fabricate a "kit" using a junkyard garrett turbo, but don't expect a massive amount of power.
Basically, it's not going to be cheap. If you want "cheap", run a N/A motor with bigger cubic inches than what you have now.
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: 84 z28 camaro?
your also gonna need fuel mods an a way to tune if you go fi . theres is all the info you need on this forum to build a turbo motor but it's not a good beginner project .you'll need to learn an understand a/f ratoi's an timing curves . it will help also if you have fabercation skills or at least friends that do . good luck tho i'm turboing my 92 camaro my main advise is study study study so you don't waste money poking an hoping .
CarGuyDennis
137
Dec 6, 2016 11:02 PM
GVMV
Aug 16, 2015 08:01 PM
