454 BBC 500HP
Old Jan 27, 2011 | 09:58 AM
BrandonSB's Avatar
Car: 1987 Z28 Camaro
Engine: 30Slow
454 BBC 500HP
is it possible to build this with a 4000$ budget
anything would be helpful!
Old Jan 27, 2011 | 11:34 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 454 BBC 500HP
are you just looking to build the motor on that budget or complete a swap into the car too?
Old Jan 27, 2011 | 12:06 PM
BrandonSB's Avatar
Engine: 30Slow
Re: 454 BBC 500HP
build the motor. i know ill also need to beef up the transmission ( will be getting a new T56 and the rear end needs to be beefed up aswell if im not mistaken. aswell a roll cage possibly?
will a t5 be able to hold up to 500HP?
Old Jan 27, 2011 | 01:28 PM
BrandonSB's Avatar
Engine: 30Slow
Re: 454 BBC 500HP
was hoping carb to pan for 4000-4500$?
Old Jan 27, 2011 | 02:53 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: 454 BBC 500HP
You can do it easily... heck you can buy a manufactured 454 bored 0.060" over for around 2 grand. Look into "781" oval port heads with oversized valves (their is actually a set on ebay for a grand that flow 302 cfm at .600"). This leaves you about a grand to buy the manifold, carb, dress up kit.
Obviously a cheaper method is buy a fully assembled big block, freshen it up with bearings, flat tops, rings and then go from there.
And no a stock T5 will not handle that. I had a 350 with 305 heads and a mild cam and after power shifting it for a few passes down the track it started to let go.
Old Jan 27, 2011 | 03:00 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: 454 BBC 500HP
Do you already have anything or are you planning to buy everything?
Old Jan 27, 2011 | 09:29 PM
BrandonSB's Avatar
Engine: 30Slow
Re: 454 BBC 500HP
planning to buy, just want a heads up ahead of time.
Old Jan 27, 2011 | 09:30 PM
BrandonSB's Avatar
Engine: 30Slow
Re: 454 BBC 500HP
so what would be the better option? beef up a T5 or a T56?
Old Jan 27, 2011 | 11:42 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: 454 BBC 500HP
I'm pretty sure a beefed up T5 costs about $2100, but don't quote me on that. The T5 is nice because it is very light (I can't speak for the T56).
Old Jan 28, 2011 | 04:28 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: 454 BBC 500HP
You could buy one of mine for $4500 but you still need bits and pieces
Edelbrock 6045
454 L2399 forged pistons
Would be 9.5:1 compression
Eagle SR forged rotating assembly
You still need cam,timing chain/cover,lifters,rockers and intake and pan
4525 delivered to your door. Im in Mississauga
I have a T56 conversion too for a thirdgen for an extra 1600 if you buy the motor..Spohn crossmember/torque arm,new clutch(for one piece seal),new hydraulics,Pro. 5.0 shifter..You just need the shifter handle and rod..You will need a special clutch to fit the 2 piece BBC though
This is a brand new motor.
You can build everything for $4000 but youre going have to stay with stock crank,rods andhypereutective pistons..Nothing wrong with that
Old Jan 28, 2011 | 05:49 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: 454 BBC 500HP
BTW IMO this is a combo good for at least 500HP
Old Jan 28, 2011 | 04:51 PM
BrandonSB's Avatar
Engine: 30Slow
Re: 454 BBC 500HP
so it would be able to handle the 500+HP??
i mean a T56 would be pointless, wasted gear id probably never use 6th. lol. whats the point? aswell what type of rear would i wanna go with, i want torque and power balance ( i guess thats what everyone wants haha)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
