Engine removal
Old Feb 13, 2011 | 09:20 PM
tanda10506's Avatar
Engine removal
I'm going to be helping my brother pull the 5.0 out of his 91 Firebird. I haven't worked much on the 3rd Gen cars. If you remove the radiator/fan shield, can you pull the engine and transmission out together from the top? Also, to do that, would it be necessary to remove the front bracketry or can we leave that intact until the engine is out of the vehicle? Thanks.
Old Feb 13, 2011 | 09:26 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: Engine removal
Trick I have used that saves a ton of time is...
Disconnect everything and you can pull the engine/trans together. Jack the back of the car up as much as you can. Rear tires should be 24+ inches+ off the ground. Make sure you have a good heavy duty hoist and be careful. You can install it easily with this method also. Having the car on such an angle makes getting the long trans under there. Goodluck!
Old Feb 13, 2011 | 09:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Engine removal
Remove the accessories and brackets. And yes, remove the radiator and fan - you can get it out with radiator in, but chances are you'll make one small false move and poke a hole in it, so just remove it. Engine/tranny combo will come out as a unit, as long as you use a load leveler on the hoist.
AutoRoc's Avatar
Transmission: 4L65E
Re: Engine removal
ooh and the front bracketry should fit on the way out once the radiator is out.
Old Feb 13, 2011 | 10:49 PM
90camaro383's Avatar
Car: 1990 Camaro wide body
Engine: 421 Dart SHP SBC
Axle/Gears: 3.73 Eaton
Re: Engine removal
I got the 305 out with all the pulleys on there and with the radiator out. I did have a little problem with the crank pulley clearing, but with a little moving around every thing came out as a hole (engine and trans).
Wish I knew the trick of lifting the back half of the car at the time.
Old Feb 13, 2011 | 11:25 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: Engine removal
Yeah it will work but you'll have to pull the accessories off as well to get it out in one shot. What I find works great is taking it out in two parts, install the trans in first and than the motor. Easiest way to get the motor back in is taking one engine mount off the motor side.
Old Feb 14, 2011 | 08:17 AM
torque_is_good's Avatar
Re: Engine removal
if an auto tranny, get a cap for the tail shaft (couple bucks) so you don't drip fluid everywhere.
remove accessories including power steering (don't just move it aside)
remove radiator and fan.
vehicle on 4 jack stands.
remove speedo cable
no need to disconnect tranny coolant lines or tv cable
remove torque arm
remove drive shaft.
when ready to yank, put pressure on the chain, go underneath and remove the tranny crossmember
lift it up, you don't need a load balancer
push down on the tranny as you lift and angle
you don't need to remove motor mounts or stock exh manifolds
I just did it and just put it back in last weekend
heck of a lot easier than a 4th gen
Old May 9, 2011 | 07:53 AM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Re: Engine removal
Just out of curiosity, what is a LOAD LEVELER ??? and where do you get one..?
stone
Old May 9, 2011 | 02:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Look it up on harborfreight.com .
Old May 9, 2011 | 02:51 PM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
Re: Engine removal
Looked it up, seems like a cool thing to have.. Stone
Old May 17, 2011 | 12:42 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Re: Engine removal
i have a 305, sadly its a stick shift, so im having issues putting it back in, if i dont do it right the clutch keeps misaligning, so i think ill just drop the tranny and put it all back in one piece
Old May 17, 2011 | 01:42 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Engine removal
Did you say sadly its a stickshift? You are crazy, manuals are awesome! On a serious note, its way easier to drop it in as one unit then try and line everything up under the car. Not so bad if you have a lift, sucks if youre laying on your back...
Old May 17, 2011 | 11:45 PM
pvr007's Avatar
Engine: 305 TBI
Re: Engine removal
thanks for your reply, what i ment its that sadly its a stick shift when you look at it from the point of view that it it alot harder to keep the thing aligned, but i love stick shift, i currently own a small 4 cil s10 truck, very nice, but with 240k miles on it, it has no power left
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
