Using my TPI on another engine.
Old Feb 27, 2011 | 06:44 PM
George90GTA's Avatar
Car: 1990 GTA
Engine: 355
Is my 350 90 GTA a Generation 1 engine? Its an 87-95 motor? Is it also considered a Vortec engine? I am so confused....I know it is definitely a roller cam engine. What is the best cam to use for rougher Idle but emission friendly.
Thanks!
Old Feb 27, 2011 | 07:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Using my TPI on another engine.
Yes
Is it also considered a Vortec engine? .
No but Vortec uses same style block and internals inc roller cam
In this case;the Vortec engine commonly referred to is the L31 350 truck engine made 96 -00.
GM called all their truck engines after '88 ,Vortecs so it is possible to come across other "Vortec" engines like 6 cyl and big blocks
Old Feb 27, 2011 | 07:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Pick which one you want
You get one or the other ; not both.
The thing ( long duration / overlap ) that makes a cam " rough at idle " is also the thing that gives bad emissions and economy , but lots of power
Old Mar 1, 2011 | 02:50 PM
Car: 1990 GTA
Engine: 355
Thank you. I am now assuming that I can use the 1990 Corvette motor with the aluminum heads.
Old Mar 1, 2011 | 04:14 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
yes
Caspar
Jun 19, 2016 11:19 PM
toronto formula
Nov 10, 2015 06:17 AM
gta90
Sep 15, 2015 04:00 PM
The_Phoenix
Sep 3, 2015 10:56 PM
Sanjay
Aug 12, 2015 03:41 PM
