BB or SB?
Old Mar 12, 2011 | 10:15 AM
Nitro_Master's Avatar
Car: 89 Camaro RS
Engine: 355sbc
Transmission: TH350
Axle/Gears: not sure, but not stock.
BB or SB?
I've been researching engines for quite a while now, I am looking at replacing my poochy 350 and dropping some serious HP under the hood. This is not a project that will happen soon, but I am researching now so I don't squander my money on **** I don't need. I was thinking about getting a 540 c.i. but am not sure. I mentioned it to my father, who used to be a mechanic quite a while ago. He said my car is designed for a small block engine, and a larger engine will put strain on the car. He also said that big-blocks do not last as long as small-blocks. He had some friend a while back who had to replace his engine every 2 or 3 years. I know he knows his stuff, but this information is from 30-35 years ago, so I'm assuming today's BB engines are better built than that? The other thing I have to look at is price, for $500 more than the BB, I can get a 600 HP 383 and a 6-71 blower... either way I'd like to supercharge, but a $2500 difference would pay for my new rear end and axles... Anyone who is an "expert" in this are please give me some sound advice.
Old Mar 12, 2011 | 10:29 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: BB or SB?
Look at Shafiroffs website..some awesome bang for the buck if you want a BBC. THere are great deals on large ci rat motors these days almost doesnt pay to do a ***** out sbc..yes you CAN make a sbc fast but if you want brute killer torque no replacement for ci.
GMPP has a 572 in 2 different versions that looks like fun. Lots out there, skys the limit depending on your wallet.
Old Mar 12, 2011 | 10:30 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: BB or SB?
If someone had to replace any engine every 2-3 years then something wasn't built right or they didn't take very good care of it especially if it was a street engine. If a BBC doesn't last, GM wouldn't have put them in so many vehicles. Race engines are a little different as they're built for a lot of abuse and are taken to the edge of their limits.
No matter what engine you use, any high HP build requires a lot more than just the engine. The entire driveline needs to be beefed up to handle the extra power and the car itself needs a little help with such things such as subframe connectors, better suspension components etc.
Very few "cars" were designed for a BBC but that doesn't mean they can't be used. It's just a slightly heavier and bigger engine. The extra displacement is just a bonus. A 400 SBC has more displacement than a 396 BBC but the engines are not the same. Externally, the BBC looks the same from a 396 all the way to a 540 and a good aftermarket block can be bored out to make that 540 into a 555 or 565. An aluminum headed BBC weighs about the same as an iron head SBC so don't let the extra weight be a factor.
The trouble with a 572 is that it's a tall deck block which makes an engine swap a little more difficult. A high HP SBC is expensive. It's cheaper to build a mild BBC which puts out the same amount of power as a high HP SBC.
Old Mar 12, 2011 | 11:39 AM
Car: 89 Camaro RS
Engine: 355sbc
Transmission: TH350
Re: BB or SB?
I plan on replacing the entire drivetrain, as a stock TH350 will not handle the HP of a BB. I plan on going with a Strange rear end that AlkyIROC recommended, as well as a custom axle. Not sure on the tranny yet, tho. The only one I found that looks like it would work costs around $5900...
Old Mar 12, 2011 | 03:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: BB or SB?
I replaced my 350 with a 454 last summer, and have absolutely no regrets about doing it. The hardware to do the swap properly costs a bit more... headers, exhaust, cowl hood in some cases, etc... but the swap itself is fairly straightforward.
The 350 I had made good power, but the 454 that replaced it will make about the same HP, alot more torque, and will be alot more civilized as a street engine. I'd bet, dollar for dollar, it probably cost me less to build a 400hp 454 BBC than it did to build a 400hp 350 SBC, because you have to replace basically everything on the 350 to get there - heads, cam, intake, valvetrain, etc etc - the heads being the most expensive of the bunch by far. With my 454 I got a set of 781 (large oval port) heads on it, which will support more power completely stock and untouched than the 200cc heads I put on my 350 will, and they didn't cost me anything extra. The heads on the small block were not cheap. I'm using a TH350 behind my 454, but as stated, its a very mild 454, so I'm not too worried.
My opinion - go with the BBC, whether its a race car or street toy, you won't regret it. There isn't really any reason to spend a fortune building a 540 or 572 (which is a tall deck, which causes lots of problems by itself) for a street engine though, because you'll never get to really use it. I'd bet you would be more than happy with a healthy 454, or maybe build a stroker out of a 454 and turn it into a 496. Its a pretty common stroker and not all that expensive to build, especially compared to a 540+ which requires an aftermarket block. Its not hard to get ALOT of power out of a properly built, relatively mild 496ci with a set of properly prepped factory large oval (#781, 049) or mild aftermarket heads on it. You wouldn't need anything exotic for that, which saves money, time, and headaches.
If you wanted to just buy a new engine in a box though, I'd recommend a crate 502 from GMPP. Aluminum oval port heads and intake, 4-bolt block, forged bottom end, hydraulic roller cam, and 500hp right from the factory, warrantied, and a pretty good price too. Just needs a carb and headers, and a few other little peices. The 502 is the big bore block too, which could potentially be turned into something bigger like a 540 at some point if you wanted to.
Old Mar 13, 2011 | 02:18 PM
Car: 89 Camaro RS
Engine: 355sbc
Transmission: TH350
Re: BB or SB?
Thanks to some advice on this thread, here's the engine I am looking at getting: http://www.shafiroff.com/pro/598_1065.asp It should have more power than the 540 I was looking at, even if I put a blower on it. I'm not sure a 540 with a blower will fit under my hood, even with a 6" cowl. The tranny I am looking at getting is this one: http://www.jegs.com/i/TCI/890/271600P/10002/-1 Is that something I need to get? I am looking for a cheaper/better suggestion, something that will hold up to the engine, but not more than I need...
